Re: [Nagios-devel] Erroneous use of getcwd on lib/nspath.c
* Ricardo Jose Maraschini ([email protected]) wrote:
> Accordingly to manpages and some home made tests, getcwd returns NULL
> when an error occurs, not a value
> Following, on openbsd MAX_PATH is 1024 bytes while in linux it is 4096
> bytes, so i thought it would be ok to include and use macro
> MAX_PATH, not a fixed size of 4096.
> Also we don't need to make sizeof(path) - 1 when calling getcwd.
> Quoting manpage:
> "The size argument is the size, in bytes, of the array referenced by
> buf."
> Is it sounds resonable?
> Comments?
I keep trolling nagios and discovered that it segfaults, or, as the code
states "256 components will fail hard" with a configuration path with
more than 256 directories.
I know that a configuration with more than 256 directories is, above
all, stupid, but i do prefer to have it working even if the
administrator isn't so much clever.
So, the previous patch may be ignored cause it's included on this.
--- lib/nspath.c (revision 2409)
+++ lib/nspath.c (working copy)
@@ -5,6 +5,7 @@
#include
#include
#include
+#include
#include "nspath.h"
#ifndef PATH_MAX
@@ -64,7 +65,7 @@
char *nspath_normalize(const char *orig_path)
- struct pcomp pcomp[256]; /* >256 components will fail hard */
+ struct pcomp *pcomp = NULL;
int comps, i = 0, m, depth = 0;
char *path, *rpath, *p, *slash;
@@ -73,7 +74,10 @@
rpath = strdup(orig_path);
comps = path_components(rpath);
- memset(pcomp, 0, sizeof(pcomp));
+ pcomp = calloc(comps,sizeof(struct pcomp));
+ if (pcomp == NULL)
+ return NULL;
p = pcomp[0].str = rpath;
for (; p; p = slash, i++) {
slash = strchr(p, '/');
@@ -114,12 +118,13 @@
path = pcomp_construct(pcomp, comps);
free(rpath);
+ free(pcomp);
return path;
char *nspath_absolute(const char *rel_path, const char *base)
- char cwd[4096];
+ char *cwd[PATH_MAX];
int len;
char *path = NULL, *normpath;
@@ -127,7 +132,7 @@
return nspath_normalize(rel_path);
if (!base) {
- if (getcwd(cwd, sizeof(cwd) - 1) < 0)
+ if (getcwd(cwd, sizeof(cwd)) == NULL)
return NULL;
base = cwd;
