Re: [Nagios-devel] Nagios 3.0 hanging (10/22 CVS)
> Out of curiousity, did you compile Nagios with embedded perl support? If
> so, try
> re-compiling without it once the valgrind test has run its course and see
> if it
> still crashes. Embedded perl is known to leak, but I haven't seen it leak
> enough
> to bring Nagios to its knees within the space of a few hours. It usually
> takes
> at least a week, and bi-nightly restarts is normally enough to take care
> of that
> particular problem.
Yes I'm using the embeded perl. I'll give it a try without and see if
anything turns up as well.
-Shad
