Re: [Nagios-devel] patch: fix nagios.spec
--=-PqWCpwSgMzSDCoQhuz/2
Content-Type: text/plain
On Thu, 2004-12-30 at 15:21 +0100, Andreas Ericsson wrote:
> Rui Miguel Seabra wrote:
> > Next on my TODO:
> > * gettext support
> > * move layout to a CSS controlled one
> >=20
> > Are these two items desireable?
>=20
> I for one would strongly discourage the implementation of gettext in a=20
> system daemon. For the gui it's another matter, but that should be=20
> resolved at a later date when it is rewritten in PHP.
The daemon is last on my i18n concerns, the web GUI is way more
important, but if changing the c files proves to hard to be worth it,
I'll just go ahead and implement it with the pathologically ecletic
rubish lister.
> Layout is already (somewhat) CSS controlled, although a couple of style=20
> tags definitely needs to be removed from the cgi code. I submitted a=20
> patch some time back which includes a common.css stylesheet file. If you=20
> want to start moving to a more stylesheet-oriented design (which can=20
> only be a good thing), I suggest you start by dropping redundant and=20
> obsolete statements from the current stylesheets and add statements=20
> found in multiple files to the common.css file. Also, it would be nice=20
> to see the stylesheets actually use the cascade functionality, and drop=20
> font-family: and other tags from style-classes that doesn't need them.
This is new from nagios 2, I suppose? I've only worked with nagios 1.2,
but since 2 is now beta I guess my time is better spent working on it,
but I haven't yet looked into more than first getting it to compile as
an RPM :)
Rui
--=20
+ No matter how much you do, you never do enough -- unknown
+ Whatever you do will be insignificant,
| but it is very important that you do it -- Gandhi
+ So let's do it...?
Please AVOID sending me WORD, EXCEL or POWERPOINT attachments.
See http://www.fsf.org/philosophy/no-word-attachments.html
Content-Type: application/pgp-signature; name=signature.asc
Content-Description: This is a digitally signed message part
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.6 (GNU/Linux)
iD8DBQBB1B9Po+C50no0+t4RAjCcAJ0dU2UA4+I3a3lcfjW1PfrQgFkTRwCguEkl
/Q6IDKrv7g+Fgye07IqIu68=
=8aWD
-----END PGP SIGNATURE-----
--=-PqWCpwSgMzSDCoQhuz/2--
