Make sure fping is in your path when running configure..
On Wed, 12 Jun 2002, Benoit Mortier wrote:
> On Wednesday 12 June 2002 01:16, Subhendu Ghosh wrote:
> > I haven't really tested the spec file recently..
> > does the normal configure process find it? it should since cconfigure now
> > looks in your PATH for program locations..
> no i didn't, the file is in /usr/sbin.fping not /usr/bin and the permissions
> are rwsr-xr-x
> > On Mon, 10 Jun 2002, Benoit Mortier wrote:
> > > hi,
> > > i grabed cvs today and compiling with the spec file it can't find the
> > > fping program, altough it is installed
> > > the package i use is fping-2.4b2-2, it is recompiled on my redhat 7.3
> > > the binary fping is installed in /usr/bin/fping
