This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01CB8CB0.402A5E8C
Content-Type: text/plain
Folks,
I'm running nagios 3.2.2 on SLES 10 SP2
# HOST AND SERVICE PERFORMANCE DATA PROCESSING COMMANDS
# These commands are run after every host and service check is
# performed. These commands are executed only if the
# enable_performance_data option (above) is set to 1. The command
# argument is the short name of a command definition that you
# define in your host configuration file. Read the HTML docs for
# more information on performance data.
service_perfdata_command=
and
# HOST AND SERVICE PERFORMANCE DATA FILE PROCESSING COMMANDS
# These commands are used to periodically process the host and
# service performance data files. The interval at which the
# processing occurs is determined by the options above.
service_perfdata_file_processing_command=
I'm using the parameter "service_perfdata_file_processing_command" to
process performance data for pnp4nagios. The first parameter
"service_perfdata_command" is commented out. But could I still use that
first parameter? It would solve a big issue I'm having if I could use it as
I need to keep a legacy set of performance data for reports at the same time
as being able to graph a a subset of the same data.
Any help / pointers would be much appreciated.
Deborah
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
Any unauthorised distribution or copying is strictly prohibited.
Whilst Kognitio Limited takes steps to prevent the transmission of viruses via e-mail, we can not guarantee that any email or attachment is free from computer viruses and you are strongly advised to undertake your own anti-virus precautions.
Kognitio grants no warranties regarding performance, use or quality of any e-mail or attachment and undertakes no liability for loss or damage, howsoever caused.
Kognitio Limited, a company registered in England and Wales. Registered number 0212 7833. Registered Office: 3a Waterside Park, Cookham Road, Bracknell, Berks, RG12 1RB. VAT number 864 4378 92.
Kognitio Inc, a company incorporated in Delaware, principal office 180 North Stetson, Suite 3500, Chicago, IL 60601, USA
Content-Type: text/html
Differences of certain parameters set in Nagios.cfg
Folks,
# These commands are run after every host and service c=
heck is
# performed. These commands are executed only if =
the
# enable_performance_data option (above) is set to 1.&n=
bsp; The command
# argument is the short name of a command definition th=
at you
# define in your host configuration file. Read th=
e HTML docs for
service_perfdata_command=3D<command to process perfor=
manace data>
and
# HOST AND SERVICE PERFORMANCE DATA FILE PROCESSING COMM=
ANDS
# These commands are used to periodically process the h=
ost and
<FON
...[email truncated]...
