On 12/06/2011 05:02 PM, Paul M. Dubuc wrote:
> Jochen Bern wrote:
>> Am I missing something, or would this
>> be equivalent to "the Tuesday between 02-Nov and 08-Nov", which, in tu=
rn,
>> should (!) be equivalent to
>> define timeperiod {
>> timeperiod_name Election Day
>> alias Shouldnt you be out there voting for someone
>> november 2 - 8 00:00-24:00
>> exclude AllButTuesdays
>=20
> Amazing. Thanks! But until the problem with the 'exclude' directive i=
s fixed=20
> (see the known issue under 3.2.0 - 08/12/2009 at=20
> http://www.nagios.org/projects/nagiosco ... ry/core-3x)
Hence the stress on "should". :-}
> we might want to do it this way:
> define timeperiod {
> use AllButTuesdays
> Do you think this will also work?
The description of how templates work is based on the assumption that
within every definition, there's a set of possible statements that are
perpendicular to / independent of each other and that every one of these
is individually either inherited as-is from the template, expanded
(additive inheritance) from the template, or overwritten outright. This
does not hold for timeperiods, as, e.g., "December 6th" and "first
Tuesday in December" may or may not refer to the same day. I wouldn't
dare predict how the current code, much less the future code after
fixing the abovementioned bug, does/will/should handle such cases.
Having that said, I *would* expect "use AllButTuesdays" to *add* the
time intervals of AllButTuesdays to the timeperiod, rather than
*substracting* them like "exclude AllButTuesdays" should.
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
