------_=_NextPart_001_01C9A9AE.3047C22C
Content-Type: text/plain;
charset="us-ascii"
We found something in the status.dat file where plugin output containing
a windows UNC followed by the letter n was treated as a newline
character. It seems to have thrown off the cgi file when it attempted to
read status.dat in the bottom of the strace:
plugin_output=3DThe message '-1073737725' for application
'AdsmClientService' could not be formatted using library(ies): ''. The
log entry contains the following replacement strings:'ANS4005E Error
processing '\
=20
long_plugin_output=3Dtnode02\\d$\\Archive\\solutions\\solutions_tlog_2009=
0
3151900.TRN': file not found' ** EventID: 4099\n
the plugin_output line SHOULD read:
processing
'\ntnode02\\d$\\Archive\\solutions\\solutions_tlog_200903151900.TRN':
This seems to be a bug with encoding either with nrpe or with nagios.
Regards,
Justin Amburn
This email is confidential and intended for its recipient only. If you
have received this in error please delete it and notify Justin Amburn.
_____________________________________________
Sent: Friday, March 20, 2009 2:19 PM
To: Justin Amburn; '[email protected]'
Subject: RE: glibc and valgrind memcheck errors (cgi segmentation fault)
with nagios 3.06 on Redhat 4.7 x86
Here is an strace of the segmentation fault, if this is of any use to
anyone:
execve("/usr/local/nagios/sbin/status.cgi",
["/usr/local/nagios/sbin/status.cg"...], [/* 30 vars */]) =3D 0
uname({sys=3D"Linux", node=3D"nagios01", ...}) =3D 0
brk(0) =3D 0x9f3a000
access("/etc/ld.so.preload", R_OK) =3D -1 ENOENT (No such file or
directory)
open("/etc/ld.so.cache", O_RDONLY) =3D 3
fstat64(3, {st_mode=3DS_IFREG|0644, st_size=3D63655, ...}) =3D 0
old_mmap(NULL, 63655, PROT_READ, MAP_PRIVATE, 3, 0) =3D 0xb7f39000
close(3) =3D 0
open("/usr/lib/libglib-2.0.so.0", O_RDONLY) =3D 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000\327A\0004\0\0\0"...,
512) =3D 512
fstat64(3, {st_mode=3DS_IFREG|0755, st_size=3D505200, ...}) =3D 0
old_mmap(0x411000, 503692, PROT_READ|PROT_EXEC,
MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =3D 0x411000
old_mmap(0x48b000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7a000) =3D 0x48b000
close(3) =3D 0
open("/lib/tls/libc.so.6", O_RDONLY) =3D 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\276$\0004\0\0\0"...
, 512) =3D 512
fstat64(3, {st_mode=3DS_IFREG|0755, st_size=3D1547540, ...}) =3D 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS,
-1, 0) =3D 0xb7f38000
old_mmap(0x237000, 1240284, PROT_READ|PROT_EXEC,
MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =3D 0x237000
old_mmap(0x360000, 16384, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x129000) =3D 0x360000
old_mmap(0x364000, 7388, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) =3D 0x364000
close(3) =3D 0
-1, 0) =3D 0xb7f37000
mprotect(0x360000, 8192, PROT_READ) =3D 0
mprotect(0x233000, 4096, PROT_READ) =3D 0
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7f376c0,
limit:1048575, seg_32bit:1, contents:0, read_exec_only:0,
limit_in_pages:1, seg_not_present:0, useable:1}) =3D 0
munmap(0xb7f39000, 63655) =3D 0
time(NULL) =3D 1237583737
brk(0x9f5b000) =3D 0x9f5b000
open("/usr/local/nagios/etc/cgi.cfg", O_RDONLY) =3D 3
fstat64(3, {st_mode=3DS_IFREG|0664, st_size=3D9593, ...}) =3D 0
mmap2(NULL, 9593, PROT_READ, MAP_PRIVATE, 3, 0) =3D 0xb7
...[email truncated]...
Original poster: ustin Amburn=2
