Re: [Nagios-devel] High latencies problem.
Could someone light me about how to use something else than command pipe to
improve performance?
On Tue, 17 Feb 2009 08:32:32 -0800, "D. Emmanuel Feinsmith"
wrote:
> Alessandro,
Its inefficiency primarily arises when it needs to either
> receive passive checks (through the command pipe bottleneck)
> The key to nagios scalability and latency reduction is to educe the #
> of fork/exec's to the smallest amount possible and keep away from the
> command pipe as much as you can if you are passive-check heavy.
> Daniel.
