I have installed the fresh copy of NagiosXI
The installation went OK
By the end of the installation, I was asked to set the password for nagiosadmin user
Once set I was able to successfully login the Nagios XI GUI, however,
I was unable to login Nagios Core Config Manager using the same user/password.
please advise.
10x.
Unbale to login Nagios Core Config Manager
Re: Unbale to login Nagios Core Config Manager
The Core Config Manager takes a separate authorization. You can set this in the Admin->Reset Security Credentials page.
