[Nagios-devel] Notification interval & escalation overlapping
Hi all,
First I would like to thank the Nagios developers for providing us this
wonderful tool and sharing it with the community.
I am using Nagios 2.2 and there seems to be a bug when using escalation
overlapping with different notification intervals.
What I want to achieve is this:
For all service and hosts notifications an email is to be sent to the
system administrators list with a notification interval of 20 minutes.
When a critical or down notification (not for warnings) is not
acknowledged within 20 minutes an email should be sent to the managers list.
The managers only want to get 1 notification to report the critical or
down state and a recovery notification whenever the status is recovered
but only for recoveries that they initially got a notification for.
To achieve this I created the following escalation definition templates:
define serviceescalation{
name mgmt
first_notification 2
last_notification 3 ; if I put 2 here, they never get the
contact_groups mgmt
notification_interval 0 ; if I put 20 here, they get 2
critical notifications and no recovery
escalation_period 24x7
escalation_options u,c,r
register 0
name admins
first_notification 3
last_notification 0
contact_groups admins
notification_interval 20
escalation_options w,u,c,r
register 0
define hostescalation{
name host-mgmt
last_notification 3
contact_groups mgmt
escalation_options d,u,r
register 0
name host-admins
last_notification 0
register 0
All hosts and services have the admins as contact group with a 20
minutes notification interval.
First I tried only adding an escalation entry for the mgmt group (worked
fine in version 1.3):
use mgmt
hostgroup_name internet-servers
service_description PING
use host-mgmt
The result is that I get the first notification to the admins and 20
minutes later I get the escalation notification to the mgmt and then
nothing anymore.
Then I tried adding an escalation for the admins:
use admins
use admins
But no result either.
The only way I can almost make it work is by changing the management
template notification interval to 20 and setting the last notification
to 2. The admins get the reminders this way, but the mgmt never gets the
recovery notification.
Just a thought, but what would make everything a lot easier is the
possibility of defining first_notification, last_notification,
notification_interval, escalation_period and escalation_options in the
contacts definition (contacts.cfg).
Since it is advised to work with templates to make things more easy, why
don't the service definitions inherit most of the parameters like
contact groups, escalations, notification interval... from the host
definitions unless specified in the service definition?
Do I submit this as a feature requests?
Sorry for this long email, I wanted to supply all relevant information.
Thanks for any help you can give me to make this work.
Kind regards,
Dirk.
