Ethan Galstad wrote:
> While doing some debugging of NDOUtils, I've noticed something bad.
> Event broker modules like ndomod.o will cause Nagios to segfault if they
> are overwritten on the filesystem while they are in use.
> I assume this is due to the way dlopen() deals with object files. I was
> under the assumption that a complete copy of the module was kept in
> memory once it was loaded, but perhaps its mmap()'d.
> The segfault is easily reproducible every time I overwrite ndomod.o
> while in use. Even if the "new" version of the file doesn't differ from
> the old.
> Anyone know more details of how this works, or better yet, how to
> avoid/deal with it?
When a program still has a descriptor to the file, the kernel retains the
diskblocks pointed to until that descriptor is made invalid (ie, close()'d).
I just tested this with modules though, and it doesn't work.
Tested locking the file too, and that didn't work either.
Hmm... The only way out I see is to copy the file to a different directory
and loading it from there, but I'm not sure it's worth it. What should we
do when we fail to copy it, fe? Load from the original location? Not load
the module at all? Either way out is wrong, for a certain value of right.
For reference, the only bug I found in glibc/BUGS with any connection to
dlfcn is this one::
Severity: [ *] to [***]
[ **] Closing shared objects in statically linked binaries most of the
times leads to crashes during the dlopen(). Hard to fix.
Since nagios isn't compiled statically, this doesn't apply, and it doesn't
crash in dlopen(), but rather when running functions in the file.
OP5 AB www.op5.se
