--0015175cd0e2eb8b7804ca43b9bb
Content-Type: text/plain; charset=ISO-8859-1
https://github.com/willixix/nagios/comm ... 7e#L0L3474
was
the cause of issues I see with latest code, so I'm reverting it in my
branch. And as far as I can tell opts2str function does not actually add
new lines, at least not in master branch, and in my opinion it shouldn't to
keep things consistent with new lines added in fcache_host & fcache_service
just like on other fprintf lines there
Plus to that it did indeed ignore specified path of objects_cache_file, but
that one was specific to my branch (as a result of another change made that
was not in sync with my previous changes)
On Thu, Sep 20, 2012 at 10:53 PM, William Leibzon wrote:
> mm. something else is wrong, I see that it did the file before getting to
> xodtemplate. will debug more
> On Thu, Sep 20, 2012 at 10:23 PM, William Leibzon wrote:
>> This did not fix CGIs, those would bypass trying to read main config file
>> and try to go directly for default cached objects file. This is
>> in xodtemplate_read_config_data and in addition to that issue macros are
>> wrong there with #ifdef NSCORE inside #ifdef NSCORE.
>> On Sun, Sep 16, 2012 at 2:32 PM, Andreas Ericsson wrote:
>>> On 09/16/2012 05:13 PM, Joerg Linge wrote:
>>> > Am 16.09.2012 um 16:27 schrieb Andreas Ericsson :
>>> >> Well, that's by design. The objects.cache should only be written to
>>> once.
>>> >> Or do you mean that it gets created but is empty?
>>> > Correct.
>>> > object_cache_file was created using the wrong path
>>> (/usr/local/nagios/var/objects.cache as defined in includes/locations.h
>>> instead of /omd/sites/ng4/var/nagios/objects.cache defined in nagios.cfg )
>>> > But the file contains just the header.
>>> Righto. I figured it out and a fix is pushed to both github and to
>>> svn. Thanks for helping out.
>>> Andreas Ericsson [email protected]
>>> OP5 AB www.op5.se
>>> Tel: +46 8-230225 Fax: +46 8-230231
>>> Considering the successes of the wars on alcohol, poverty, drugs and
>>> terror, I think we should give some serious thought to declaring war
>>> on peace.
>>> Everyone hates slow websites. So do we.
>>> Make your web apps faster with AppDynamics
>>> Download AppDynamics Lite for free today:
>>> http://ad.doubleclick.net/clk;258768047;13503038;j?
>>> http://info.appdynamics.com/FreeJavaPer ... nload.html
>>> _______________________________________________
>>> Nagios-devel mailing list
>>> [email protected]
>>> https://lists.sourceforge.net/lists/lis ... gios-devel
Content-Type: text/html; charset=ISO-8859-1
https://github.com/willixix/nagios/commit/e08c8=
9830e96fce1361fb15527a2a6503a9f1b7e#L0L3474=A0was the cause of issues I=
see with latest code, so I'm reverting it in my branch. And as far as =
I can tell opts2str function does not actually add new lines, at least not =
in master branch, and in my opinion it shouldn't to keep things consist=
ent with new lines added in fcache_host & fcache_service just like on o=
Plus to that it did indeed ignore specified path of objects_=
cache_file, but that one was specific to my branch (as a result of another =
change made that was not in sync with my previous changes)
On Thu, Sep 20, 2012 at 10:53 PM, William Leibzo=
n <[email protected]> wrote:<blockquote class=3D"gma=
il_quote" style=3D"margin:0 0 0 .8ex;border-left:1px #ccc solid
...[email truncated]...
