On Mon, 13 Jun 2005, Lee Fitz wrote:
> one person told me that Im overusing active monitoring.
> In my design, Im using mostly active monitoring' via Nagios.
> I am using passive monitoring (and a little active) for 27 machines but am
> planning on using active monitoring for 30-50 more because of security
> restrictions.
> The location of the Nagios Monitoring Host is inside a secure area,
> consequently the only way I can get at the 30-50 additional machines outside
> the secure area is via active monitoring since I can send out of the secure
> area but no passive monitoring can come in.
> I did NOT see anything in the documentation or user group traffic that
> implied that I could NOT (or should not) use more active monitoring than
> passive monitoring. The documentation seems to indicate that I could use all
> active monitoring if I decided to.
> Any thoughts would be appreciated.
> Thanks
> -Lee
You should be fine - most installations are primarily active.
The only time one worrys about active is if your are doing a lot of
individual check_by_ssh (or like) checks in a small interval that could
cause target CPU spikes.
-sg
