Re: [Nagios-devel] Is nagios core extendable? (fwd)
Hi Andreas,
well I must describe more information about solution:
in our concept is Nagios - only part; "collector" for a lot of values, which are
send (as passive tests, or active test) from each node = we are distinguish
between sensors and tests(test poduces only state and "easy" plain text.
Sensor produces more structured information that can describe any
mysql table(s) (it is META data and data selfs), I may append one row =
output from sensor, that contain "pre-evaluation":
It could be good.
Yes, I don't need defined mysql tables (in advance time), each sensor defines table
self and Nagios can create table if not exist and saves data into tables... One note:
first is update if operation is "failed" then insert.
One format in structured format is binary_code.
Yes, but event broker module does solve problems such is cumulative logs (we have
service data = meta data and "data". Where I can read more about event broker developing
(I have only "halloworld module", but I need more info, about modules design, how connect
to nagios, possibilities...more :))?
Well, I can go back, from hard source code programming and modify to module programming,
I think that is probably better solution (maintainability).
Lada
Sample one row sensor output code:
> You can do that, provided the resulting fork is still licensed
> under GPL, the same as Nagios is today.
> > 1. direct saving results into DB (not by using NDO etc..., but direct - ASAP
> but refllex possibilities
> > DB and work node ~ such is latency, IOWait, busy Waiting, timeouts, etc...),
> That would be stupid for a lot of reasons, not least of which is
> that you'll have to maintain it separately forever and ever.
> > 2. "predictive - modul", but no stnd. Nagios modul (this isn't
> > good place for more explanation).
> You're wrong. This is exactly the right place for more
> explanation.
> > Very short: Not concept "Event done then send message" but
> predicitve-statistically: "EVENT PROBABLY
> > is able to occur then send message".
> You can get at this information without modifying the Nagios
> core. If you still want this to run in the core of Nagios, a
> far better way of achieving that is to write an eventbroker
> module.
> > Have I got your suport for this solutions?
> That depends on what you mean by our support. I won't write
> it for you, but if it turns out to be a nifty piece of code
> I might use it for something and then ofcourse I'll send you
> bugreports and patches.
> > Are these solutions correct?
> Since you haven't created the solutions yet, that's impossible
> to tell.
> > What is your opinions on this?
> That you should refrain from altering the Nagios core if you
> can manage by getting the required data from other places,
> such as by loading a module or writing a log-parsing program.
> > Thanks for reply
> You're welcome.
> > Note:
> > Sorry, but I have very good reason for this short info - no detail for more
> info.
> That sentence doesn't really parse. Anyway, you'll find it hard to get help
> from the community while you're withholding details about your project.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
> This SF.net email is sponsored by:
> High Quality Requirements in a Collaborative Environment.
> Download a free trial of Rational Requirements Composer Now!
> http://p.sf.net/sfu/www-ibm-com
> Nagios-devel mailing list
> [email protected]
