On Fri, 31 Jan 2003, Johnson, Joel wrote:
> I'm about 50% done with a simple perl script to parse the status.log
> file into a 'status.xml' file (which I'm using as a first step to a new
> front end for nagios). It's rough, but it works. Would anyone be
> interested in using it? If so, I can clean it up and daemonize it, allow
> it to accept command parms, etc.
> Thanks,
> Joel Johnson
Are you by any chance planning on using the Frontier::RPC modules while
daemonizing? (XML-RPC)
-sg
