Re: [Nagios-devel] novel idea for performance optimization
This is a multi-part message in MIME format...
------------=_1115594853-66727-106
Content-Disposition: inline
Dear Folks,
I am writing to thank you for your letters and say,
On Sun, May 08, 2005 at 11:34:09PM +0200, Andreas Ericsson wrote:
> sean finney wrote:
> >hey folks,
.. lots of interesting stuff snipped ..
> Come to think of it, it should actually be possible to multiplex a
> fairly large number of checks from a single thread using fdopen(3) and
> select(2). This would let one get rid of locking problems with a
> multi-threaded approach and would probably be highly efficient since the
> fork()'ed children just sit around and wait all the time anyway.
FWIW, threads aside (on grounds of ignorance), I think a multiplexed Nag
was tried with patches to 1.x from an .au developer (the discussion was
fairly brief on Nag-devel in the last 2-3 years; it probably occurred
before you started to contribute to the project).
IIRC, he said his approach was like that used by squid.
If anyone is interested, perhaps I can find the thread (He only posted
once or twice, perhaps did enough to get over the partic problem he was
facing with and then ... silence).
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Lead Developer
Yours sincerely.
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1115594853-66727-106--
