Actually we're doing this now by utilizing livestatus to query for the info=
and then issuing a delete comment that way. This seems easier though.
Dan
-----Original Message-----
Sent: Thursday, March 24, 2011 11:48 AM
To: Nagios Developers List
Subject: [Nagios-devel] New Nagios external commands for downtime deletion
Hi!
I've just committed into SVN trunk 4 new downtime deletion commands:
* DEL_HOSTGROUP_HOST_DOWNTIME;hostgroupname
* DEL_HOSTGROUP_SVC_DOWNTIME;hostgroupname
* DEL_HOST_SVC_DOWNTIME;hostname
* DEL_DOWNTIME_BY_START_TIME_COMMAND;starttime;comment
This allows downtime deletions to work in a master/slave setup, because the=
current mechanism of deletion by id number doesn't work in a distributed e=
nvironment.
The first three have been in Opsview for years, but the last one is new, so=
we're adding all these into Nagios core today.
There are tests written to process the external command (in test_commands.c=
) and the downtime deletion (in test_downtime.c - which caught two bugs!).
A few questions for Ethan:
* I assume svn trunk is the right place to put this - I note that in bran=
ches/ there a feature branches. Can I suggest that you use trunk for latest=
development and create a stable branch instead. This is what we do for Ops=
view and it works very well (we tried the other way of development branches=
but caused a lot of unnecessary maintenance)
* Where is the documentation to go for new external commands? Google says=
here: http://old.nagios.org/developerinfo/ext ... dlist.php=
but it is broken, and the domain is old.nagios.org
Ton
Enable your software for Intel(R) Active Management Technology to meet the
growing manageability and security demands of your customers. Businesses
are taking advantage of Intel(R) vPro (TM) technology - will your software=
=20
be a part of the solution? Download the Intel(R) Manageability Checker=20
today! http://p.sf.net/sfu/intel-dev2devmar
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
Original poster: on Voon [mailto:[email protected]]=2
