[Nagios-devel] dnx version 0.16 release announcement
Everyone,
I'm pleased to announce the release of version 0.16 of the DNX package.
DNX is a modular extension for the Nagios network monitoring package.
One of the most significant enhancements is that we now set file
system right properly during installation if you're running "make
install" as root. Not setting file system rights correctly was the
root cause of most of the startup problems with both the client daemon
and the server module.
Another significant addition is that of a more generic init script for
non-SUSE linux distros - "make install" automatically detects SUSE
platforms and installs the correct version - thanks to Alberto
Villegas for this contribution.
This version of DNX provides the following enhancments:
- Fixed install bugs - mostly related to improper file system rights.
- Debug output is now realistic - not pumping out droves of useless info.
- Added new configure options for specifying log directory.
- Fixed miscellaneous build system problems.
- Fixed rpm build issue - getaddrinfo failing under OBS.
- Fixed doxygen generation issues related to incorrect exclude dir list.
- Added new unit test for dnxClient - tests proper client daemonization.
- Added generic init script for non-SUSE platforms.
Please download DNX version 0.16 and give it a try. I think you'll
find the installation much cleaner since version 0.15.
Thanks and enjoy!
John
