Re: [Nagios-devel] Nagios 3.0 RC2: Segmentation faults after
do you have NDO enabled? If yes, try to disable it and then restart =
Nagios.
Maybe the ndo-version doesn't fit to your Nagios version...
christian
"I sense much NT in you, NT leads to Blue Screen.=20
Blue Screen leads to downtime, downtime leads to suffering. NT is the =
path to the darkside."=20
- Unknown Unix Jedi =20
> -----Original Message-----
> From: [email protected]=20
> [mailto:[email protected]] On Behalf=20
> Of Christian Schneemann
> Sent: Thursday, February 14, 2008 10:38 AM
> To: [email protected]
> Subject: [Nagios-devel] Nagios 3.0 RC2: Segmentation faults=20
> after starting
>=20
> Hallo,
> our test Nagios dies after every restart with a segmentation=20
> fault since last=20
> week.
> I have tried to find the error with gdb. I hope someone can=20
> point me to my=20
> error.
>=20
>=20
> d139:/etc/nagios/objects/hosts #=20
> gdb --args /usr/sbin/nagios /etc/nagios/nagios.cfg=20
> GNU gdb 6.6
> Copyright (C) 2006 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public=20
> License, and you are
> welcome to change it and/or distribute copies of it under=20
> certain conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show=20
> warranty" for details.
> This GDB was configured as "x86_64-suse-linux"...
> (no debugging symbols found)
> Using host libthread_db library "/lib64/libthread_db.so.1".
> (gdb) run
> Starting program: /usr/sbin/nagios /etc/nagios/nagios.cfg
> [Thread debugging using libthread_db enabled]
> [New Thread 47105982427648 (LWP 15658)]
>=20
> Nagios 3.0rc2
> Copyright (c) 1999-2008 Ethan Galstad (http://www.nagios.org)
> Last Modified: 01-29-2008
> License: GPL
>=20
> Nagios 3.0rc2 starting... (PID=3D15658)
> Local time is Tue Feb 12 10:37:24 CET 2008
> [New Thread 1082132800 (LWP 15661)]
>=20
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 47105982427648 (LWP 15658)]
> 0x000000000043b90a in process_check_result_queue ()
> (gdb) bt
> #0 0x000000000043b90a in process_check_result_queue ()
> #1 0x000000000041c536 in reap_check_results ()
> #2 0x0000000000429119 in handle_timed_event ()
> #3 0x0000000000429701 in event_execution_loop ()
> #4 0x00000000004120fe in main ()
> (gdb) s
> Single stepping until exit from function process_check_result_queue,=20
> which has no line number information.
> 0x0000000000437c50 in sighandler ()
> (gdb) s
> Single stepping until exit from function sighandler,=20
> Caught SIGSEGV, shutting down...
> 0x00002ad7b7394c10 in __restore_rt () from /lib64/libc.so.6
> (gdb) s
> Single stepping until exit from function __restore_rt,=20
> (gdb) s
>=20
> (gdb)
>=20
>=20
>=20
>=20
> Regards
> --=20
>=20
> SUSE LINUX Products GmbH,
> Maxfeldstr. 5, D - 90409 N=FCrnberg
>=20
> Phone:=A0=A0+49 (0)911 - 740 53 0
> e-mail:=[email protected]
> SUSE LINUX Products GmbH, GF: Markus Rex
> HRB 16746 (AG N=FCrnberg)
>=20
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> Nagios-devel mailing list
> [email protected]
> https://lis
...[email truncated]...
