Activating Nagios XI 2011R1.1
jon.bilderback
Post by jon.bilderback »
I've just updated, and when I enter the activation code, this message appears at the top of the page:
SQL: SQL Error [nagiosxi] : ERROR: duplicate key violates unique constraint "xi_options_pkey"
The activation page says: "Activation key accepted. Thank you!"
However, all web pages still have the message asking me to activate the product.
Running on RHEL 5 vm
rdedon
Re: Activating Nagios XI 2011R1.1
Post by rdedon »
Could you try clearing your cache in your browser and see if that fixes it? Also, be sure to log out completely as well.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
jon.bilderback
rdedon wrote:Could you try clearing your cache in your browser and see if that fixes it? Also, be sure to log out completely as well.
Just tried that, and still get the same error.
jon.bilderback
I just tried to configure the Active Directory Integration, and again, had the same error message.
admin
Site Admin
Post by admin »
Looks like this is related to a bug we tracked down in an earlier release with the Postgres database options. This isn't an activation-specific bug - it affects other things that require access to tables in Postgres.
Running this command should fix this problem for you:
/usr/local/nagiosxi/tools/fix_postgres_sequences.sh
Try that and let us if it fixes the problem (or not). Thanks!
Ethan Galstad
President
jon.bilderback
That fixed it. Thank you.
tonyyarusso
Post by tonyyarusso »
Excellent - glad to hear it. Let us know if you encounter any further issues.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
