Re: [Nagios-devel] Purpose of use_syslog
Jon Angliss wrote:
> On Tue, 2 Jun 2009 09:07:48 -0600, "Steven D. Morrey"
> wrote:
>> Ahhah! I see the error of my ways.
>> I just needed to look a bit higher up, basically the write_to_syslog is being called from both logging functions, and the use_syslog option is checked only in the write_to_syslog function as a sort of bail out point.
>> That makes sense, but I wanted the option to mean something a little different, so now I've modified the write_to_all_logs and write_to_all_logs_with_timestamp to check for use_syslog and only write out the regular log file if use_syslog is false.
>> This way I don't double my logging overhead. Now use_syslog means use_syslog only :)
> This is how I'd expected it to be as well, but not how it actually is.
> Application bug? Or documentation bug? Either way, it's a little
> vauge, and could do with clearing up.
I like the current behaviour, but I'd accept a patch to take 'only' or something
as an argument to "use_syslog" to make the behaviour you're talking about happen.
Do note that history browsing won't work in the CGI's if nagios.log doesn't get
written at all, so this option should very, very clearly be marked in such a way
that unsuspecting new users don't shoot themselves in the foot. Recreating a
proper nagios.log from the syslog messages is ofcourse possible, but I'd rather
avoid having to try it if at all possible. Especially given most distributions
tendency to only keep syslog files around for four weeks before rotating them
into oblivion. Four weeks means users that want availability reports on a month
or so won't even realize the data they need isn't where it should be before it
doesn't exist anymore. Bad Thing(tm) indeed.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
