--------------010206030809040902060408
Hello Mike,
I dont get any messages on /var/log/messages concerning ndoutils. I get
this message on nagios.cfg
[1139855284] ndomod: Successfully connected to data sink. 0 queued
items to flu
sh.
[1139855284] Event broker module '/usr/local/nagios/bin/ndomod.o'
initialized suc
cessfully.
The ndo2db is running ok, but no messages in the logs either. It
creates the ndo.sock file and running.
If I am running ndomod.o to dump to a file, I dont need to have
ndo2db, right?
In the ndo.dat file I get this messages and nothing else.
HELLO
PROTOCOL: 2
AGENT: NDOMOD
AGENTVERSION: 1.3
STARTTIME: 1139858944
DISPOSITION: REALTIME
CONNECTION: FILE
CONNECTTYPE: INITIAL
INSTANCENAME: default
STARTDATADUMP
Nagios runs ok, allthought does't dump anyting.
Thanks for any clue in the matter Mike.
[]s.
Mike Koponick wrote:
> Alessandro,
> Make sure you also have the following running:
> /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
> (your directory structure may vary)
> Also, you have want to send a tail of your /var/log/messages (If you
> are sending to syslog) just to make sure you are seeing the module is
> being initialized and connecting to the SQL server.
> I have been using NDO for quite a while and don't have any issues. I
> do need to upgrade to the stable release of software this week, but
> currently I'm using 2.0rc.
> Mike
> -----Original Message-----
> *From:* [email protected]
> [mailto:[email protected]] *On Behalf Of
> *Alessandro Ren
> *Sent:* Monday, February 13, 2006 12:11 PM
> *To:* [email protected]
> *Subject:* [Nagios-devel] ndoutils help.
> Hello,
> i've been trying to use ndoutils and I can no get nagios to dump
> anything. The broker gets loaded and logs in nagios.log that has been
> loaded, and either dumping in file or to a unix socket, I dont get
> anything.
> I've made some changes on the code to dump all logs to mysql by
> myself already, but I'd like to use ndoutils, as they dump more
> information and it'd be more complience for futures upgrades.
> I am using nagios-2.0 stable release and tried ndoutis-1.2 and
> ndoutils-1.3, the broker_module entry is in the nagios.cfg, it creates
> de file ndo.dat and writes the start informantion but does't dump
> anything.
> Thanks.
> __________________________________________________
> *Alessandro Ren*
> */OpServices/*
> */Luciana de Abreu, 471 - Sala 403/*
> */Porto Alegre, RS - CEP 90570-060/*
> *(* phone 55(51)3061-3588
> *4* fax 55(51)3061-3588
> *Q* mobile 55(51)8151-8212
> *:* email [email protected]
*Alessandro Ren*
/*OpServices*/
/*Luciana de Abreu, 471 - Sala 403*/
/*Porto Alegre, RS - CEP 90570-060*/
Content-Type: text/html; charset=ISO-8859-1
Hello Mike,
items to flu
sh.
initialized suc
cessfully.
The ndo2db is
...[email truncated]...
