Re: [Nagios-devel] [PATCH] Distinguish between warning and critical
Flap detection is to prevent rapid pages due to a service that
constantly changes state. So if a service is transitioning from WARNING
to CRITICAL every minute, each time Nagios checks the state will have
changed and it will send out a new notification to reflect that change.
I am hoping to avoid the issue where a service that is in WARNING for
long enough will eventually page every person in the escalation chain.
(see original email).
-Gius
shadih rahman wrote:
> I asked this question on both mailing list in the past. Can someone
> point out why we chose to ignore flapping option in hostescalation and
> serviceescalation? Thanks
> On Thu, Nov 19, 2009 at 9:43 PM, Mark Gius > wrote:
> Hendrik Baecker wrote:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Am 18.11.09 01:02, schrieb Mark Gius:
> >> The patch adds 4 configuration directives to service escalations
> >> definitions:
> >> first_warning_notification #
> >> last_warning_notification #
> >> first_critical_notification #
> >> last_critical_notification #
> >> Behavior is identical to (first|last)_notification, except that
> they
> >> check against the count of warning/critical notifications
> instead of the
> >> number of total notifications.
> > Hi,
> > I really like this but what about unknown state notifications which
> > might be used?
> I thought of unknowns right after I sent the patch. We don't
> really use
> them in our deployment, so I wasn't thinking about them during
> implementation. It's easy enough to add.
> > What about hostescalations? Would you patch them too?
> I was going to question the usefulness of this, but they can be both
> "down" and "unreachable." I'll get an updated patch up sometime
> next week.
> I'd like some feedback on how I modified the CGIs to display the new
> variables. I was hesitant to add a bunch more columns to that table,
> considering it's already pretty large, so I just put all 4 of the new
> thresholds in the same table entry (all, warn, crit, unknown).
> Putting
> all of the thresholds in the same column is unclear without
> reading the
> source. I can add new table columns if that's the "proper" thing to
> do. Or if somebody has a solution I'm not thinking of I'd love
> for the
> config output to be very clear.
> -Gius
> Let Crystal Reports handle the reporting - Free Crystal Reports
> 2008 30-Day
> trial. Simplify your report design, integration and deployment -
> and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Nagios-devel mailing list
> [email protected]
> Cordially,
> Shadhin Rahman
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> [email protected]
