By any chance, are you using NDO utils? If so, do you see the same
results with NDO utils disabled?
Does the load/process count, on your machine increase at a similar rate
to your nagios latency?
There are also several settings in nagios.cfg that can cause degraded
nagios performance, depending on how they are tuned. Perhaps you could
make a copy of your nagios.cfg available for view? (with any
confidential information edited out, of course)
-Aaron
Hendrik Bäcker wrote:
> Hi Ethan,
> thanks for investigating into this.
> >> Andreas Ericsson schrieb:
> >>> Are you using embedded perl? If so, turn that off.
> >> Small update:
> >> Even if ePN is disabled, the curve of latency goes up after 6-8 hours
> >> runtime.
> >> Hendrik
> > Hendrik - Can you try enabling the "experimental" auto-rescheduling
> > feature and see if it helps? Set the following vars in the
> nagios.cfg file:
> > auto_reschedule_checks=1
> > auto_rescheduling_interval=60
> > auto_rescheduling_window=300
> > The rescheduling window of 300 seconds assumes that you have an average
> > check interval of 5 minutes. If your avg. check interval is different,
> > change the window to match.
> > If epn is disabled, I'm not sure what would cause latency to go up after
> > several hours, other than checks getting scheduled in "clumps" (too
> > close together).
> So, to understand it, the rescheduling window 'lies' over the next 300
> seconds like a filter and should try to reschedule these checks to fit
> bests into the window?
> > I'll be looking forward to see what that results are from this.
> I've just enabled this just a few minutes ago, will report the effects
> tomorrow (after let it run for some time greater 2 hours
> Hendrik
> This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a browser.
> Download your FREE copy of Splunk now >> http://get.splunk.com/
> Nagios-devel mailing list
> [email protected]
