Re: [Nagios-devel] Changing config files while nagios is running
Hi Raphael,
you are right:
The WEB-Interface gets confused, if you are changing your config, 'cause of
the CGI's handnling and display nagios status, but nagios is running
correctly, so it's on your hand to decide wether you have to restart nagios
after any small changes or make some changes for a while and then restarting
nagios, i've written some small scripts, which check nagios-config
#!/bin/sh
and restart nagios
#!/bin/sh
PATH=/usr/local/bin:/usr/bin:/usr/X11R6/bin:/bin:.
# Nagios-cfg checken und Nagios durchstarten
/usr/local/nagios/bin/check_nagioscfg >/dev/null
RETVAL=`echo $?`
#echo $RETVAL
if [ $RETVAL = 0 ]; then
echo "[`date +%s`] RESTART_PROGRAM;`date +%s`"
>/usr/local/nagios/var/rw/nagios.cmd
fi
Hope this helps ...
Regards
Michael
Am Dienstag, 8. Juni 2004 16:12 schrieb Raphael Mueller:
> Dear all,
> currently, I often change the configuration files of Nagios (Ver. 1.1)
> because we get a lot of new equipment these days.
> If I change the config files while Nagios is running, the Nagios web
> page starts to mess up, e.g. several devices disappear.
> My question: Am I doing something against the good practices if I edit
> the config files without stopping the Nagios service first?
> I don't understand too much about the architecture of Nagios, but
> according to chapter "Stopping And Restarting Nagios" of the online
> documentation
> http://nagios.sourceforge.net/docs/1_0/stoprestart.html
> Nagios should only check the config files and (re)read them if I start,
> restart or reload the service.
> So, maybe, it's just the web interface which gets confused about my
> config changes?
> Of course, I could use a second set of config files to work on. Then, I
> would write a script which checks the copied set of config files, stops
> the service, copies them to the directory used by Nagios and start the
> service again....
> Maybe, I'm just thinking to far or there is a know workaround... any
> help is appreciated.
> Kind Regards,
> Raphael
Diese E-Mail wurde auf Viren ueberprueft.
www.mimesweeper.com
