Re: [Nagios-devel] Some errors with SIGSEGV
Ethan Galstad wrote:
> Hendrik Bäcker wrote:
>> It is not only on SLES. I am able to reproduce it even on OpenSuSE
>> 10.x, Ubuntu 6.10 (edgy) and 6.07 (dapper).
>> And yes it is only when using the default "minimal" config. After get
>> rid of the -O2 Flag it runs without any problems. A few months ago I
>> thought it could something have to do with a gcc version 4.x instead
>> of 3.x.... but this is just a thought.
>> I think the list elements where deleted before they are read if there
>> is only one host (or just a few [>
> This is odd indeed. I've been running Nagios 3.a1 on Ubuntu 6.10 (edgy)
> and gcc 4.1.2 under Parallels on my MBP without problems for the last
> day or so. Haven't tried Nagios 2.x yet though. I'm downloading the
> Ubuntu fiesty beta to give a try and will see if I come across any
> problems with Nagios 3a1 or 2.8.
> Anyone using Nagios on these distros without problems? Strange that
> more people haven't reported problems given that there are packages for
> Nagios on Ubuntu, etc.
I see no problems with Nagios 3.0a1 on Ubuntu Feisty Test1?( with
updates) and on Fedora 7Test2?(with updates), both on amd64 machines
(with one and two CPUs). I do the following:
./configure
make all
su -c "make install install-config"
# copy the check plugins from the package installation directory to
/usr/local/nagios/libexec/
/usr/local/nagios/bin/nagios /usr/local/nagios/etc/nagios.cfg
--> No error
/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
--> No error
Makefile containing: Makefile:CFLAGS=-g -O2 -DHAVE_CONFIG_H
The configuration file nagios.cfg only enables:
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/localhost.cfg
Should the error happens immediately or after some time?
A Debian package for Nagios 3.0a1 is not available, also a RPM - or I'm
wrong?
Best Regards
Herbert Straub
