[Nagios-devel] embedded-perl problem (bug?)
Hi guys,
Nagios-1.0a7 segfaults without any error message when check_ifstatus.pl
is used. Nothing shows up when run, from the command line; only a
notification of SIGSEGV is shown in nagios.log.
I tried the same configuration over, after recompiling nagios -- now
without embedded-perl. This time all works fine. (probably this is not a
problem related to this specific plugin)
Nagios runs on a RedHat 7.2 i386 system.
The output from the plugin when run from the command line is:
Use of uninitialized value in sprintf at ./check_ifstatus.pl line 148.
CRITICAL: host 'dummy-router', interfaces up: 40, down: 13, dormant:
0ATM1/0.5-atm subif: down -> ATM1/0.5-aal5 layer: down ->
ATM1/0.50-atm subif: down -> ATM1/0.50-aal5 layer: down ->
Serial2/1: down -> === connection to IMEC ===E1 4/3: down ->
E1 4/4: down -> E1 4/5: down -> E1 4/6: down -> E1 4/7:
down -> E1 4/0: down -> E1 4/1: down -> E1 4/2: down ->
I hope this can help you!
If not, please let me know how I can help to debug.
All suggestions are welcome!
Regards,
Guy
