In message ,
Andreas Ericsson writes:
>Shad L. Lords wrote:
>>>> Following up on my previous message about additive inhereritance it
>>>> appears
>>>> that it only applies to the first used instance. Here is an example
>>>> config
>>>> that fails. There also appears to be an issue with canceling
>>>> inheritance.
>>> [ somewhat bizarre configuration axed out ]
>>>> Hope this helps track down some potential issues,
>>> To be perfectly honest, I've always felt it overly complicates the nagios
>>> config
>>> parsing code to even allow templates to have templates. For really large
>>> networks, where they'd obviously be of most use, it's no great chore to
>>> copy
>>> and paste one and then modify the variable that you want to alter.
>> If you have parameters set in a template then if you want to update them y
>ou
>> only have one place to do it. If you have 3k config files (or a 100k file
>> then you have thousands of places you have to modify.
>sed be thy friend
Well yes and no. I have seen a lot of variability in lists
hostgroup_name a,!b,c
hostgroup_name a,c,!b
these can be the same lists of hosts, but expressed in two different
ways. Now you want to manipulate that list hundreds or thousands of
times over. I can sed it, I won't give you odds on my getting the
config right afterwards.
>>> I'm not sure how many people use this feature in an inheritance
>>> chain like you do, and as I personally don't really see the use
>>> for it, I'd rather spend my time on other things.
I would love to use it personally.
>> If they can be fixed our config would benefit from it quite a bit.
>> It would cut down the amount of manual tweaking necessary to get
>> things to work right.
Same reason.
Using multiple templates allows me to do something like:
use standard_passive_service
use without_passive_event_correlation
use with_no_notification
to define the basic parameters for my service. It also makes it a lot
more obvious what I am trying to do. I could create one template:
use standard_passive_service-without_passive_event_correlation-with_no_notifcation
(umm assuming I didn't exceed some limit for template names
it is lot more readable (and maintainable) if I can stack the
templates.
-- rouilj
John Rouillard
My employers don't acknowledge my existence much less my opinions.
