Re: [Nagios-devel]
Re: [Nagios-devel]
Hi Joerg,
thanks for your answer!
Am 18.05.2007 um 10:09 schrieb Joerg Linge:
> The same problem on my side if nagios is compiled with "--enable-
> embedded-perl --with-perlcache"
> Can you please compile without this options ?
> Just a test to verify the situation.
$ ./configure --with-command-group=nagcmd
*** Configuration summary for nagios 3.0a4 05-08-2007 ***:
General Options:
Nagios executable: nagios
Nagios user/group: nagios,nagios
Command user/group: nagios,nagcmd
Embedded Perl: no
Event Broker: yes
Install ${prefix}: /usr/local/nagios
Lock file: ${prefix}/var/nagios.lock
Check result directory: ${prefix}/var/spool/checkresults
Init directory: /etc/init.d
Apache conf.d directory: /etc/apache2/conf.d
Mail program: /usr/bin/mail
Host OS: linux-gnu
$ make all
Enjoy.
Ok, so w/o embedded Perl no problem ... I'll try the suggestion from
Hendrik next and report back later ...
Thanks again, Ingo.
Ingo Lantschner
Vienna/Austria
Mob (+43-664) 143 84 18
