Content-Type: text/plain; charset="us-ascii"; format=flowed
Hi all,
Please find attached my patch for version 1.7.2.3 of check_nt.c. This patch
adds the ability to check disk space based on the amount of Mb left on a
partition. I wrote this because 1% of a 100Gb partition is still a lot of
space!
The command line option is -m or --mb. The logic behind the checks is
reversed against the percentage checks: the percentage method checks
against the amount of disk space used; the Mb method checks against the
amount of free space left.
I could have got the same functionality from NRPE_NT or by using a 3rd
party solution, but I haven't had cause to deploy NRPE_NT yet, so I decided
to patch check_nt.c.
Technical stuff:
I used Mb values rather than Gb values because of the use of the unsigned
long type for the percentage values, which are used extensively through out
check_nt.c. So rather than rewrite a lot of check_nt.c so you could
specify, say, -w 1.2 (Gb), I decided to use Mb value on the command line.
(Debugging revealed that when a float value is converted into an unsigned
long, you would get a negative value in that unsigned long - not good when
checking remaining disk space!)
Yves: I've submitted this patch to sourceforge.
Greg Vickers
Computer Systems Officer
Student Support and Systems,
Teaching and Learning Support Systems,
Queensland University of Technology,
Kelvin Grove Campus,
Brisbane,
Australia
CRICOS No 00213J
Ph: 07 3864 8276 Fax: 07 3864 5425
Mob: 0416 001 674 SD: #66147
--=====================_96202828==_
Content-Type: application/octet-stream; name="check_nt.c.diff"
Content-Disposition: attachment; filename="check_nt.c.diff"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...[email truncated]...
