Re: [Nagios-devel] Wildcard in servicegroup causes segmentationfault
------=_NextPart_000_002A_01C6A406.8135BEE0
Content-Type: text/plain;
charset="us-ascii"
Sorry I missed one part of your email, it seems that you already use the
latest tarball.
For the date, it's correct. Looks like Ethan only change it for releases.
Thomas
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf
> Of Thomas Guyot-Sionnest
> Sent: July 10, 2006 9:46
> To: Bernd Adamowicz; [email protected]
> Subject: Re: [Nagios-devel] Wildcard in servicegroup causes
> segmentationfault
> I'm not sure if that will help, but can you try the latest
> 2.x cvs tarball?
> You can download it from http://nagios.sourceforge.net/download/cvs/
> It fixed a similar segfault for me.
> Thomas
> > Of Bernd Adamowicz
> > Sent: July 10, 2006 8:44
> > To: [email protected]
> > Subject: [Nagios-devel] Wildcard in servicegroup causes
> > segmentation fault
> > (Hope I didn't cause too much confusion since I already posted this
> > message once bevore beeing a member of this list.)
> > Hi All,
> > I'm facing the problem, that the pre flight check from nagios causes
> > a segmentation fault, if the 'member' variable of a servicegroup
> > contains a '*' wildcard. I have just compiled the latest
> CVS tarball
> > because there have been some similiar bugs reported, but it didn't
> > fix my problem.
> > This is the part of my configuration that causes the problem:
> > # causes seg fault
> > define servicegroup{
> > servicegroup_name Swapspace
> > alias Services checking the swap space on
> > disk
> > members BSS-MGMT-SMServer*,Swapspace
> > Of course there is at least one host which matches the
> > pattern 'BSS-MGMT-
> > SMServer*,'.
> > Seems the '*' after 'BSS-MGMT-SMServer' causes the problem. If I
> > switch to a single host name, everything works fine:
> > # causes no seg fault
> > disk
> > members BSS-MGMT-SMServer-Test04b,Swapspace
> > I run Nagios in GDB. This is the output:
> > >nagios-2-x-cvs/base # gdb nagios
> > (gdb) run -v /usr/local/nagios/etc/nagios.cfg
> > Starting program: /root/temp/nagios-2-x-cvs/base/nagios -v
> > /usr/local/nag
> > ios/etc/nagios.cfg
> > [Thread debugging using libthread_db enabled]
> > [New Thread 182901004448 (LWP 424)]
> > Nagios 2.4
> > Copyright (c) 1999-2006 Ethan Galstad (http://www.nagios.org)
> > Last Modified: 05-31-2006
> > License: GPL
> > Reading configuration data...
> > Program received signal SIGSEGV, Segmentation fault.
> > [Switching to Thread 182901004448 (LWP 424)]
> > 0x0000002a95a452c5 in free () from /lib64/tls/libc.so.6
> > (gdb)
> > -------- end of gdb output
> > Maybe this will give someone of you a hint, what might have
> happened.
> > (I was a little bit confused about the last modified date of
> > 05-31-2006,
> > but I'm shure I got the latest tarball.)
> > Maybe someone has help. Thanks in advance.
> > - Bernd Adamowicz (Bernd)
> > The mailing list archive is found here:
> > http://www.nagiosexchange.org/nagios-devel.33.0.html
> > Using Tomcat but need to do more? Need to support web
> > services, security?
> > Get stuff done quickly with pre-integrated technology to make
> > your
...[email truncated]...
