Re: [Nagios-devel] Database access via Nagios
Thanks. I will take a look into the Event Broker stuff.
But just out of interest, does anyone know how the NINJA and NBOARD web
front-ends access stored Nagios data?
This might give me a clue as to how to best tackle this task.
Thanks again in advance.
Marc Powell wrote:
> On Tue, Mar 16, 2010 at 8:58 AM, Mohammed Murphy
> wrote:
> I need a way of accessing the underlying database
> without actually knowing what it is. So the question is, does Nagios
> have some library or functionality to cope with this scenario?
> Nagios provides an Event Broker interface that allows you to hook into
> nagios using a generic interface but does not provide any kind of
> database abstraction layer. That's up to you to create or find.
> Depending on what your requirements are, the Event Broker API may suit
> your needs. You can look at NDOUtils as an example of it's use.
> I'm not aware of any database agnostic libraries. Even on the surface,
> every database is different and would require some difference in the
> methods to access and talk to it so you going to have to have *some*
> awareness of the databases that you'll be taking to and be able to
> support them.
> Marc
> formerly marc /at/ ena.com
> Download Intel® Parallel Studio Eval
> Try the new software tools for yourself. Speed compiling, find bugs
> proactively, and fine-tune applications for parallel performance.
> See why Intel Parallel Studio got high marks during beta.
> http://p.sf.net/sfu/intel-sw-dev
> Nagios-devel mailing list
> [email protected]
