Google DNS IP Match
Ben.Patrick
Google DNS IP Match
Post by Ben.Patrick »
Hoping I am not reposting a question, but could not find it on the search function.
Keep getting a failure on the Google DNS IP Match as the IP addresses seem to change for google. I maged to get it working with the string of IP addresses that I was getting yesterday, but today the range has changed.
Is there a way to get this working as it seems it needs to be an exact match to what is returned, or do I ditch Google and choose a different website?
Ben
rdedon
Re: Google DNS IP Match
Post by rdedon »
I believe that unfortunately this does change sporadically as I had done the same with, I believe, 4 ip addresses that changed the next month but then changed back at some point. There is most likely a pool that can be searched out but I do not know it off hand.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
tonyyarusso
Post by tonyyarusso »
Man, I totally had a patch in the works for this a few months ago. Let me see if I can find that code again...
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
Ben.Patrick
Thanks Tony, much appreciated. I've just removed it for now. :D
Post by Box293 »
From a different perspective, I thought this was intentional.
What I mean is that the "out of the box Nagios XI VM" shows you what a critical service looks like.
