Re: [Nagios-devel] NDO utils bug/explanation [Solved]
--------------040605040402070502070801
Hi Marco,
you are very welcome and thanks for your reply. It was nice getting
deeper into the code for this use case and I'm assured it will help me
on the development of Icinga IDOUtils either way removing the blocking
behavior and enhance the debugoutput (next to rewriting the db handling
code for other rdbms like Postgres, Oracle, SQLite).
Kind regards,
Michael
Frassinelli, Marco wrote the following on 22.09.2009 09:24:
> Hi Michael
> Thank you very much for the explanations. Finally I found the problem,
> it was a Nagios issue, too many reload where interrupting data flow.
> Now everything works very well.
> By
> Marco
> *From:* Michael Friedrich [mailto:[email protected]]
> *Sent:* domenica 20 settembre 2009 2.34
> *To:* Nagios Developers List
> *Subject:* Re: [Nagios-devel] NDO utils bug/explanation
> Hi,
> Frassinelli, Marco wrote:
> Hello
> The process of starting ndo2db and then Nagios makes sure that there
> is actual data within the DB. If there is an outdated data within the
> DB it needs to be removed before Nagios even sends new data. So the
> process of trimming those table entries is truly intentional at the
> beginning (so-called pre-launch state where the if condition matches).
> If ndo2db fails for some reason, those data will remain within the
> database and then removed during the next start.
> Ok, when the parent ndo2db process starts. But not
> when the child starts.
> Considering the fact that the process runs daemonized and forks a
> child for each ndomod client connection, that is truly wrong. See the
> NDOUtils documentation page 8:
> http://www.scribd.com/doc/17608352/Nagios-NDOUtils
> Going deeper into the code in ndo2db.c:main you will recognize that
> after initialization stuff that the standalone daemon condition matches.
> /* standalone daemon... */
> else{
> /* create socket and wait for clients to connect */
> if(ndo2db_wait_for_connections()==NDO_ERROR)
> return 1;
> This function opens the socket wether tcp or unix. Then the parent
> forks a child to handle client data (0 = everythings ok, -1 = error).
> /* fork... */
> new_pid=fork();
> switch(new_pid){
> case 0:
> #endif
> /* child processes data... */
> ndo2db_handle_client_connection(new_sd);
> /* close socket when we're done */
> close(new_sd);
> #ifndef DEBUG_NDO2DB
> return NDO_OK;
> break;
> Parent runs in a while loop and if child has died on the client
> connection, it forks a new one.
> The child then reads the data from the socket within
> ndo2db_handle_client_connection. If there's nothing on the socket, the
> client connection was lost and the while(1) terminates (also on
> errors), meaning the child to terminate too. The child performs the
> memory cleanup and db disconnect and then the process of the parent
> accepting new client connection and forking a child for each client
> connection starts again.
> Just look that up in the code, it's quite nice commented.
> /* check for completed lines of input */
> ndo2db_check_for_client_input(&idi,&dbuf);
> This function also decides if the actual client needs to be
> disconnected. So there are 3 main options that can lead to the
> termination of the child:
> * socket read result fails with -1, eagain/eintr ->
> http://linux.die.net/man/2/read
> * socket read is empty
> * client input is wrong protocol (idi->disconnect_client)
> If one line has been read from the socket, it comes to
> ndo2db_handle_client_input where the data frame is analyzed.
...[email truncated]...
