Re: [Nagios-devel] Fix memory leak on notifications.c and
On 10/10/2011 02:21 PM, Dorian Guillois wrote:
> Hi,
> I found another memory leak in service_notification and
> host_notification functions into notifications.c and
This breaks things though. If all volatile macros are free()'d and
there's more than one contact to notify, the rest of the contacts
won't get all the macros they actually need (such as hostname,
service description and things like that). That's why we don't call
clear_volatile_macros_r() from there in the first place.
Since I'm guessing you've run this through valgrind, it should be
fairly easy to locate the spot where the leak happens and thus fix
it properly by just releasing the leaked memory.
> xodtemplate_read_config_data function into xodtemplate.c.
This one looks good though, even though it's a one-time leak in a
very rarely used codepath. I doubt anyone would stumble across it in
a normal setup, but good catch all the same.
OP5 AB www.op5.se
on peace.
