[Nagios-devel] Small problem with configfile dirs on XFS on Linux
--=-4SCT70sEVtEBgcefIjW9
Content-Type: text/plain
I was having some interesting problems today with one
of the latest CVS snapshot running on a Linux system with
XFS filesystems. The code in xodtemplate.c find out that
Linux supports Linux has _DIRENT_HAVE_D_TYPE but on XFS
the d_type is set to DT_UNKNOWN which means one should use
stat to figure out what type of file it really is. After
finding out this frustrating bug I went out and did a
quick and dirty patch. Attached is the patch which works
around the DT_UNKNOWN value and fixed my problems on XFS
filesystems with configfile directories.
Marco van Wieringen
ELM Consultancy B.V.
Content-Disposition: attachment; filename=nagios_xodtemplate.c.diff
Content-Type: text/x-patch; name=nagios_xodtemplate.c.diff; charset=iso-8859-1
--- xodtemplate.c.org 2004-05-11 20:53:14.603841000 +0200
+++ xodtemplate.c 2004-05-11 20:54:42.015725000 +0200
@@ -358,16 +358,24 @@
x=strlen(dirfile->d_name);
if(x>4 && !strcmp(dirfile->d_name+(x-4),".cfg")){
-#ifdef _DIRENT_HAVE_D_TYPE
- /* only process normal files and symlinks */
- if(dirfile->d_type!=DT_REG && dirfile->d_type!=DT_LNK)
- continue;
-#endif
/* create the full path to the config file */
snprintf(config_file,sizeof(config_file)-1,"%s/%s",dirname,dirfile->d_name);
config_file[sizeof(config_file)-1]='\x0';
+#ifdef _DIRENT_HAVE_D_TYPE
+ /* only process normal files and symlinks */
+ if (dirfile->d_type==DT_UNKNOWN) {
+ x=stat(config_file,&stat_buf);
+ if(x!=0){
+ if(!S_ISREG(stat_buf.st_mode) && !S_ISLNK(stat_buf.st_mode))
+ continue;
+ } else {
+ if(dirfile->d_type!=DT_REG && dirfile->d_type!=DT_LNK)
+ continue;
+#endif
/* process the config file */
result=xodtemplate_process_config_file(config_file,options);
@@ -378,7 +386,16 @@
/* recurse into subdirectories... */
- if(dirfile->d_type==DT_DIR || dirfile->d_type==DT_LNK){
+ if(dirfile->d_type==DT_UNKNOWN || dirfile->d_type==DT_DIR || dirfile->d_type==DT_LNK){
+ if(x!=0){
+ if(!S_ISDIR(stat_buf.st_mode) && !S_ISLNK(stat_buf.st_mode))
+ continue;
+ } else {
+ continue;
/* ignore current, parent and hidden directory entries */
if(dirfile->d_name[0]=='.')
@@ -386,7 +403,7 @@
/* check that a symlink points to a dir */
- if(dirfile->d_type==DT_LNK){
+ if(dirfile->d_type==DT_LNK || (dirfile->d_type==DT_UNKNOWN && S_ISLNK(stat_buf.st_mode))){
/* copy full path info to link buffer */
snprintf(file_name_buffer,sizeof(file_name_buffer)-1,"%s/%s",dirname,dirfile->d_name);
- continue;
-#endif
+ if(x!=0){
+ continue;
+ } else {
+ continue;
+#endif
+ if(x!=0){
...[email truncated]...
