Re: [Nagios-devel] Problems with many hanging
Thomas Guyot-Sionnest wrote:
>> From: [email protected]
>> [mailto:[email protected]] On Behalf
>> Of Ethan Galstad
>> Sent: December 21, 2006 11:57
>> To: Nagios-Devel
>> Subject: Re: [Nagios-devel] Problems with many hanging Nagios
>> processes (Nagios spawning rogue nagios processes eventually
>> crashing Nagios server)
>> Good work on nailing down the problem to the command buffer slots!
>> Sounds like this problem might affect a number of users, so I
>> think we
>> need to patch Nagios. There are two possible solutions:
> Ethan,
> Do you think this bug could be the cause of my issue where I loose passive
> check results under load / when many passive checks comes in at the same
> time?
> Thanks,
> Thomas
Hi Thomas - I think I must have missed your original problem description
in the mass of emails that I've been behind on. :-) I guess you'd have
to test the new code to see if that fixes your problem for sure.
If I'm correct, you shouldn't loose passive checks under heavy load
conditions unless you exhaust physical memory and something like the
infamous OOM killer starts killing processes. Under normal situations,
passive checks would just be delayed under heavy load.
Ethan Galstad,
Nagios Developer
Email: [email protected]
