Re: [Nagios-devel] vanished bug numbers in the nagios mantis tracker
On 08/06/2012 05:12 PM, John P. Rouillard wrote:
> In message ,
> Andreas Ericsson writes:
>> On 08/03/2012 05:15 PM, John P. Rouillard wrote:
>>> In message ,
>>>> On 08/03/2012 10:27 AM, Wim Hoekman wrote:
>>>>> On 2012-08-01 10:37, Andreas Ericsson wrote:
>>>>>> This one might resolve itself in Nagios 4, when we change how checks
>>>>>> are run. I won't investigate it further until that's out anyway though.
>>>>> The release of Nagios 4 would be a great time to import the Nagios patch
>>>>> I've submitted a while ago.
>>>>> (Subject: Additional image for action_url in host and service
>>>>> definitions patch)
>>>>> That patch required a change to the object abi, so it was not included
>>>>> in any minor release.
>>>> Is there a reason why we just can't make this a custom variable with
>>>> special meaning in the UI?
>>>> I'm especially uninterested in patches that move more UI code into the
>>>> core, since that's something that really should be going away rather
>>>> than increase.
>>> One of the things that frustrated me to no end when creating the
>>> external correlation event broker
>>> (http://www.cs.umb.edu/~rouilj/sec_nagio ... manual.txt) was
>>> that the broker architecture provided no mechanism for the plugin to
>>> add items to the objects and provide parsers for the objects in config
>>> files.
>> That would be pretty awesome, but "adding items to the object" is simply
>> not possible. C-objects are carved in stone once the code is compiled,
>> and nothing but the module will ever know or care about the extra data.
> So add a field that is a pointer to a nagios maintained data store for
> each object. Where each object in the datastore is a key/value (blob
> pointer) pair. "adding items to the object" wasn't meant as add a new
> field. More along the lines of add a new item to a linked list in the
> object.
Why on earth would you prefer O(n) complexity over O(1)? Do you realize
that you're requesting something that's both slower and more complex than
what I proposed?
>>> Custom variables help a little bit but introduce the need to parse the
>>> value on every event which is not acceptable. The value should be
>>> parsed once into a quickly accessible form (e.g. bitfield) and carried
>>> around with the object.
>> Well, no. You might want to add things other than flags in such variables
>> and you may well have several modules at once competing for the dubious
>> honor of putting extra junk into objects.
> The object carries the data as a linked list, static array of
> pointers.... rather than as a named item in the struct. As long as the
> name for each item is unique there isn't a problem. (e.g. ec_ in my
> examples). Nagios could even provide a register function to allow
> modules to determine which prefixes are already registered so if Eric
> Charles' plugin tries to register ec_ but my event correlation plugin
> already has ec_ loaded, it gets an error message and gets to chose a
> new prefix. Heck nagios could even return a prefix code that is used
> by the module. There are many ways to handle the issue.
Not really, no, because user documentation has to work too or users
won't be able to use Eric Charles' module and yours at the same time.
>>> Are there any plans to add something like:
>>> add_new_custom_variable_property(SERVICE_OBJECT, "_ec_active_action", \
>>> func_parse_ec_active_action);
>>> where:
>>> void * func_parse_ec_active_action(char * property_name,
>>> char * property_value)
>>> int add_property_value(*service_object, "_ec_active_action", void * valu
>> e)
>>> void * get_property(*service_object, "_ec_active_action");
>>> to allow the brokers to register parsers for specific custom
>>> variables?
>> No, and in time for Nagios 4 I doubt we'll do that since it doesn't
>> really require a major version bump to be added and I just don't have
>> the time for it right now. Patches are of
...[email truncated]...
