Re: [Nagios-devel] Testers Needed: New 3.x Speedups
------=_Part_21267_18540566.1204267621854
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Hi Ethan,
Have you look at my patch for speed up the host circular check?
Thanks a lot,
I'll check the new code too.
Jean
On Fri, Feb 29, 2008 at 12:29 AM, Ethan Galstad wrote:
> I just posted new code to CVS that I would like some testers to verify.
> The CVS commits introduce new skiplist algorithms for lists that are
> used for searching for objects, etc.
> We've been doing some testing of Nagios 3 with 50,000 hosts/services on
> a rather low end box to find performance problems. Startup times in our
> configuration (tested with the -sx command line) indicated that it took
> about 4 minutes to read and process the (uncached) config files. The
> new code does the same operations in just 18 seconds, so its a huge
> performance increase.
> In order to ensure the new code doesn't have bugs (it affects major
> portions of the logic), I'm looking for people with large/complex
> configs to help verify the new code's correctness.
> This can be done by doing two sets of tests - the first using binaries
> from the 3.0rc3 release and the other with binaries the new CVS code.
> 1. Test timing of startup routines with:
> time /usr/local/nagios/bin/nagios -sx /usr/local/nagios/etc/nagios.cfg
> 2. Make sure that no errors are reported and that the object counts for
> each type of object (host, service, etc.) are the same for 3.0rc3 and
> latest CVS code:
> /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
> Please post to the list with any bugs you may encounter, or if you see
> great speed improvements. :-)
> FYI, the current event queue implementation has very bad performance
> with large installs. Startup timing (-sx) tests with Nagios 3.0rc3
> showed it taking ~100 seconds to initially 50,000 events. I did a bit
> of testing with the new skiplist algorithm, and the event scheduling
> time dropped to *1* second. This will be implemented in a CVS commit in
> a few days.
> Ethan Galstad
> Nagios Developer
> ___
> Email: [email protected]
> Web: www.nagios.org
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> Nagios-devel mailing list
> [email protected]
Content-Type: text/x-patch; name=circular-parents2.patch
X-Attachment-Id: f_fd8dtlzt0
Content-Disposition: attachment; filename=circular-parents2.patch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...[email truncated]...
