Tobias Mucke wrote:
> Hi list,
> found the problem, at least I think to have found the problem.
> Actually function neb_set_module_info does not operate on the
> nebmodule struct but on the mod_handle it got from its caller. The
> latter is from type lt_dlhandle. To set an info of type
> NEBMODULE_MODINFO_* does not make sense.
> Two problems arose by this and I fall into both. Writing informations
> to the module by neb_set_module_info works for some of the
> NEBMODULE_MODINFO_*. Some other lead to a segfault. The second problem
> is, if you have overwritten the NEBMODULE_MODINFO_TITLE you overwrite
> the filename of the lt_dlhandle and the module can't be unloaded
> anymore.
> I have written a patch. Since I am not a very experienced C programmer
> please review it carefully before applying to official Nagios code.
Excellent patch Tobias! This bug has been around for quite a while, and
affects the Nagios 2.x code as well as 3.x. I'll get the patch into CVS
shortly.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
