Re: [Nagios-devel] cfg_dir recursive?
On 5/3/08 4:25 PM, local.coder wrote:
> Jo Rhett wrote:
>> I'm using FreeBSD 6.2-REL. There's nothing about FreeBSD that would
>> prevent recursion in subdirectories.
Conversely, I don't _think_ there's anything about the recursion code
that is OS-specific. Then again, I've only ever run it on Linux. Have
a look in xdata/xodtemplate.c:258 if you want to the relevant code.
> Using the current 3.x I am using recursion on FreeBsd 6.2 and have no
> issues. Please make sure your config files have a .cfg extension as the
> config file directs. I have been using recursion since before 3.0
> without issues. I even double checked on sub dirs and that read
> correctly as well.
Ditto. I'm running Nagios 2.x on RHEL3/4/5, and cfg_dir recursion works
with empty subdirs just fine, e.g.:
cfg_dir=/etc/nagios/servers Short of the .cfg extension not being on your files I would have to look
> at file perms next.
Well, since Jo said it works when pointing explictly to the subdirs (and
verified the dir perms), I don't think either of these is the problem.
Jo, could you cut and paste your relevant configuration bits for
enabling the cfg_dir / cfg_file directives?
-tt
