[Nagios-devel] long_plugin_output problems?
Is it right the way nagios 3.2.0 is escaping the strinf for the
long_plugin_output?
It is strange to me the way it is doing. Bellow is the output from
nrpe escaped by nagios in a check.
Tks.
long_plugin_output=NRPE Plugin for Nagios\\\\nCopyright (c) 1999-2007
Ethan Galstad ([email protected])\\\\nVersion: 2.8.1\\\\nLast Modified:
05-10-2007\\\\nLicense: GPL v2 with exemptions (-l for more
info)\\\\nSSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher
required\\\\n\\\\nUsage: check_nrpe -H [-n] [-u] [-p ] [-t
] [-c ] [-a ]\\\\n\\\\nOptions:\\\\n
-n = Do no use SSL\\\\n -u = Make socket timeouts return
an UNKNOWN state instead of CRITICAL\\\\n = The address of
the host running the NRPE daemon\\\\n [port] = The port on which the
daemon is running (default=5666)\\\\n [timeout] = Number of seconds
before connection times out (default=10)\\\\n [command] = The name of
the command that the remote daemon should run\\\\n [arglist] = Optional
arguments that should be passed to the command.
Multiple\\\\n arguments should be separated by a space. If
provided, this must be\\\\n the last option supplied on the
command line.\\\\n\\\\nNote:\\\\nThis plugin requires that you have the
NRPE daemon running on the remote host.\\\\nYou must also have
configured the daemon to associate a specific plugin command\\\\nwith
the [command] option you are specifying here. Upon receipt of
the\\\\n[command] argument, the NRPE daemon will run the appropriate
plugin command and\\\\nsend the plugin output and return code back to
*this* plugin. This allows you\\\\nto execute plugins on remote hosts
and fake the results to make Nagios think\\\\nthe plugin is being run
locally.\\\\n\\\\n
