[Nagios-devel] plugins 1.4.13 segfault on Solaris
--Boundary_(ID_IpHNBo05IR7G5CyavaxTRg)
Content-type: text/plain; charset=us-ascii
Content-transfer-encoding: 7BIT
Hi - We are trying to get Nagios 3.0.6 working by building from source
using Sun Workshop 6 update 2 C 5.3 on Solaris 9. All compiles ok
but we are getting 'Segmentation fault' when running ./check_ping -H
localhost -w 100,20% -c 500,60%. If I comment out a call
to fperfdata() it will work. Maybe an issue with asprintf? Anyone
know what could be causing the plugins to fail when run from
the command ilne? We have 1.4.1 installed in production working fine.
Thanks!
--Chuck
Content-type: text/html; charset=us-ascii
Hi – We are trying to get Nagios 3.0.6 working by
building from source using Sun Workshop 6 update 2  C 5.3 on Solaris 9.  All
compiles ok
but we are getting ‘Segmentation fault’ when
running ./check_ping –H localhost –w 100,20% -c
issue with asprintf?   Anyone know what could be causing the plugins
Thanks!
--Chuck
--Boundary_(ID_IpHNBo05IR7G5CyavaxTRg)--
