[Nagios-devel] Segmentation fault with ndo2db
--------------070600060306080401040108
Content-Type: text/plain; charset=ISO-8859-7; format=flowed
I was trying to get NDOutils to work on an FC4 machine with
kernel version 2.6.14-1.1644_FC4 and Nagios 2.0 but I run into a
problem with ndo2db.
It seems that the ndomod add-on runs OK but ndo2db runs into a
seg fault. Here is the output from it after enabling some of the DEBUG
-sh-3.00$ /usr/sbin/ndo2db -c /etc/nagios/ndo2db.cfg
BYTESREAD: 511
RAWBUF:
HELLO
PROTOCOL: 2
AGENT: NDOMOD
AGENTVERSION: 1.2
STARTTIME: 1139821845
DISPOSITION: REALTIME
CONNECTION: UNIXSOCKET
CONNECTTYPE: INITIAL
INSTANCENAME: default
STARTDATADUMP
202:
1=300
2=0
3=0
4=1139821381.911401
73=1139821381
74=262144
72=Event broker module '/usr/sbin/ndomod.o' initialized successfully.
999
200:
1=104
2=0
3=0
4=1139821381.911415
105=Nagios
107=2.0
104=02-07-2006
102=25107
999
200:
1=100
2=0
3=0
4=1139821381.913492
105=Nagios
107=2.0
104=02-07-2006
102=25107
999
300:
4=113982138
USED1: 511, BYTES: 0, LINES: 0
BUF[0]='\n'
HANDLING: ''
USED2: 510, BYTES: 1, LINES: 1
BUF[0]='\n'
HANDLING: ''
USED2: 509, BYTES: 2, LINES: 2
BUF[5]='\n'
HANDLING: 'HELLO'
USED2: 503, BYTES: 8, LINES: 3
BUF[11]='\n'
HANDLING: 'PROTOCOL: 2'
USED2: 491, BYTES: 20, LINES: 4
BUF[13]='\n'
HANDLING: 'AGENT: NDOMOD'
USED2: 477, BYTES: 34, LINES: 5
BUF[17]='\n'
HANDLING: 'AGENTVERSION: 1.2'
USED2: 459, BYTES: 52, LINES: 6
BUF[21]='\n'
HANDLING: 'STARTTIME: 1139821845'
USED2: 437, BYTES: 74, LINES: 7
BUF[21]='\n'
HANDLING: 'DISPOSITION: REALTIME'
USED2: 415, BYTES: 96, LINES: 8
BUF[22]='\n'
HANDLING: 'CONNECTION: UNIXSOCKET'
USED2: 392, BYTES: 119, LINES: 9
BUF[20]='\n'
HANDLING: 'CONNECTTYPE: INITIAL'
USED2: 371, BYTES: 140, LINES: 10
BUF[21]='\n'
HANDLING: 'INSTANCENAME: default'
USED2: 349, BYTES: 162, LINES: 11
BUF[13]='\n'
HANDLING: 'STARTDATADUMP'
Segmentation fault
Andreas Kasenides
Tel: +357 - 22892714
e-mail: Andreas.Kasenides%at%cs.ucy.ac.cy
(replace the %at% above with @)
Content-Type: text/html; charset=ISO-8859-7
kernel version 2.6.14-1.1644_FC4 and Nagios 2.0 but=A0 I run into a
BYTESREAD: 511
RAWBUF:
HELLO
PROTOCOL: 2
AGENT: NDOMOD
AGENTVERSION: 1.2
STARTDATADUMP
202:
1=3D300
2=3D0
3=3D0
4=3D1139821381.911401
73=3D1139821381
74=3D262144
72=3DEvent broker module '/usr/sbin/ndomod.o' initialized successful=
ly.
999
200:
1=3D104
2=3D0
3=3D0
4=3D1139821381.911415
105=3DNagios
107=3D2.0
104=3D02-07-2006
102=3D25107
999
200:
1=3D100
2=3D0
3=3D0
4=3D1139821381.913492
105=3DNagios
107=3D2.0
104=3D02-07-2006
102=3D25107
999
</pr
...[email truncated]...
