Re: [Nagios-devel] Services check and unreachable host status
-----Message d'origine-----
De=A0: [email protected] =
[mailto:[email protected]] De la part de =
Andreas Ericsson
Envoy=E9=A0: jeudi 27 septembre 2007 14:44
=C0=A0: Nagios Developers List
Objet=A0: Re: [Nagios-devel] Services check and unreachable host status
Gabes Jean wrote:
>=20
> De : [email protected] =
Andreas Ericsson
> Envoy=E9 : jeudi 27 septembre 2007 14:07
> =C0 : Nagios Developers List
> Objet : Re: [Nagios-devel] Services check and unreachable host status
>=20
>>> That's an option, ofcourse, but it sounds to me as if you really =
should
>>> be patching the GUI files to hide services that are on hosts that =
are
>>> down. That way you should get what you want while maintaining report
>>> correctness.
>=20
> Yes, but I prefer modify some C lines than PHP :)
>>The web-interface is written in C, so it'd be the same there.
Sorry, I speak about another one, Oreon, in PHP.
--=20
OP5 AB www.op5.se
