Re: [Nagios-devel] nagios-cvs: PROCESS_HOST_CHECK_RESULT for
Gerd Mueller wrote:
> Hi developers,
> the recent nagios-cvs version doesn't unterstand the external command
> "PROCESS_HOST_CHECK_RESULT". No matter what hoststate is used the host
> is always up afterwards even it was "pending" before :-(.
> Logfile:
> [1170421254] EXTERNAL COMMAND:
> PROCESS_HOST_CHECK_RESULT;200100_AG_LEX_ULIT_Butzbach.11.1;1;via
> webinterface|
> You can easily test it via the webinterface. And yes, of course, nagios
> and the host are configured to accept passive checks.
> Any ideas?
> Cheers,
> Gerd
Thanks for the report Gerd. This bug was due to the host check logic
changes made for Nagios 3. I just posted a patch to CVS. Thanks again!
Ethan Galstad,
Nagios Developer
Email: [email protected]
