--------------020008010508010101070302
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Hi Ethan,
when configuring with --enable-DEBUGALL, there are some minor typos in
base/config.c, base/utils.c
and xdata/xodtemplate.c.
Details see attachments,
regards,
Peter
name="nagios-3.0a1.p1.txt"
Content-Disposition: inline;
filename="nagios-3.0a1.p1.txt"
--- config.c.bak 2007-03-13 13:04:47.000000000 +0100
+++ config.c 2007-03-13 13:05:01.000000000 +0100
@@ -1204,7 +1204,7 @@
check_orphaned_hosts=(atoi(value)>0)?TRUE:FALSE;
#ifdef DEBUG1
- printf("\t\tcheck_orphaned_hosts set to %s\n",(check_orphaned_host==TRUE)?"TRUE":"FALSE");
+ printf("\t\tcheck_orphaned_hosts set to %s\n",(check_orphaned_hosts==TRUE)?"TRUE":"FALSE");
#endif
name="nagios-3.0a1.p2.txt"
filename="nagios-3.0a1.p2.txt"
--- utils.c.bak 2007-03-01 19:19:15.000000000 +0100
+++ utils.c 2007-03-13 13:16:20.000000000 +0100
@@ -2940,7 +2940,7 @@
printf("get_raw_command_line() start\n");
#endif
#ifdef DEBUG1
- printf("\tInput: %s\n",cmd);
+ printf("\tInput: %s\n",cmd_ptr);
#endif
/* clear the argv macros */
name="nagios-3.0a1.p3.txt"
filename="nagios-3.0a1.p3.txt"
--- xodtemplate.c.bak 2007-03-06 16:24:51.000000000 +0100
+++ xodtemplate.c 2007-03-13 13:57:02.000000000 +0100
@@ -2826,7 +2826,7 @@
/* add the custom variable */
if(xodtemplate_add_custom_variable_to_contact(temp_contact,customvarname,customvarvalue)==NULL){
#ifdef DEBUG1
- printf("Error: Could not add custom variable '%s' for contact.\n",varname);
+ printf("Error: Could not add custom variable '%s' for contact.\n",customvarname);
#endif
my_free((void **)&customvarname);
my_free((void **)&customvarvalue);
@@ -3262,7 +3262,7 @@
if(xodtemplate_add_custom_variable_to_host(temp_host,customvarname,customvarvalue)==NULL){
#ifdef DEBUG1
- printf("Error: Could not add custom variable '%s' for host.\n",varname);
+ printf("Error: Could not add custom variable '%s' for host.\n",customvarname);
#endif
@@ -3657,7 +3657,7 @@
if(xodtemplate_add_custom_variable_to_service(temp_service,customvarname,customvarvalue)==NULL){
#ifdef DEBUG1
- printf("Error: Could not add custom variable '%s' for service.\n",varname);
+ printf("Error: Could not add custom variable '%s' for service.\n",customvarname);
#endif
--------------020008010508010101070302--
