It's currently supported in Nagios 1.0, using compile time options for MySQL
or PostGreSQL.
However, check:
http://www.nagios.org/upcoming.php
In particular, these lines:
8. DB support for retention data is being dropped
9. DB support for extended information is being dropped
Also note that at least one individual has begun work on an XML approach,
ie, manage the configuration via XML, then generate the Nagios config files
from the XML file(s).
HTH.
jc
> -----Original Message-----
> From: Chris Fedde [mailto:[email protected]]
> Sent: Friday, February 14, 2003 12:11 PM
> To: [email protected];
> [email protected]
> Subject: [Nagios-devel] Databased configuration
> Please forgive me if this is a FAQ. I have been unable to
> find an obvious
> note about this in the FAQ or the archive of the mailing list.
> I'm about to embark on a project to back end the
> configuration files with a
> database. I'm doing this to support a provisioning process for a
> potentially large number of hosts and services. Has there
> been any work
> already done in this area? I'd be interested to hear any
> info or pointers
> that you might have to share.
> Thanks in advance
> Chris Fedde
> This SF.NET email is sponsored by: FREE SSL Guide from Thawte
> are you planning your Web Server Security? Click here to get a FREE
> Thawte SSL guide and find the answers to all your SSL
> security issues.
> http://ads.sourceforge.net/cgi-bin/redi ... thaw0026en
> Nagios-devel mailing list
> [email protected]
