Thanks for the note. I should actually remove all "?" in that
section of the code. The only place its really used is in the
display_info_table() function in cgiutils.c, so I'll make changes
there.
On 25 Apr 2002 at 20:10, Bradey Honsinger wrote:
> I've been working on setting up Nagios 1.0a7 on our internal network, and I
> noticed that the default_user_name option in cgi.cfg is broken. In
> cgi/auth.c:123, the current username is set to "?" if authentication isn't
> being used, but later the default_user_name is used only if the current
> username is the empty string (""). The only time the default_user_name will
> be used is if malloc() fails! Here's the code snippet:
> ----cgi/auth.c:123---
> /* grab username from the environment... */
> temp_ptr=getenv("REMOTE_USER");
> if(temp_ptr==NULL){
> authinfo->username="?";
> authinfo->authenticated=FALSE;
> else{
> authinfo->username=(char *)malloc(strlen(temp_ptr)+1);
> if(authinfo->username==NULL)
> authinfo->username=""; set to ""--when malloc fails!
> else
> strcpy(authinfo->username,temp_ptr);
> if(!strcmp(authinfo->username,"")){
> else
> authinfo->authenticated=TRUE;
> ---> if(!strcmp(authinfo->username,"") &&
> strstr(input_buffer,"default_user_name=")==input_buffer){
> temp_ptr=strtok(input_buffer,"=");
> temp_ptr=strtok(NULL,",");
> else
> else
> ----end snippet----
> A simple patch is included below--it just checks authinfo->username against
> "?" instead of "". I've tested it out, and it works for me. A better way
> might be to check if authinfo->authenticated is FALSE--I'll leave the choice
> up to whoever checks it in.
> - Bradey
> diff -ruN nagios-1.0a7/cgi/auth.c nagios-1.0a7-patched/cgi/auth.c
> --- nagios-1.0a7/cgi/auth.c Wed Mar 6 17:34:32 2002
> +++ nagios-1.0a7-patched/cgi/auth.c Wed Apr 24 20:15:22 2002
> @@ -120,7 +120,7 @@
> strip(input_buffer);
> /* we don't have a username yet, so fake the
> authentication if we find a default username defined */
> - if(!strcmp(authinfo->username,"") &&
> + if(!strcmp(authinfo->username,"?") &&
> Nagios-devel mailing list
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
