Antonio Grassi wrote:
> Hi list. Maybe this message should have been sent to nagiosplug-devel, sorry
> if that is the case.
> I've been trying NDOUtils, and got it working with MySQL. I've also seen
> that there are plans to add support for PostgreSQL storage, and browsing the
> code I see there is already some work in that direction. I've also seen
> there are a couple of messages in nagios-devel and nagiosplug-devel about
> versions with certain support for PostgreSQL, using 1.4b2 and 1.4b3 versions
> of NDOUtils.
> I tried Nagios 3.0b5 and NDOUtils 1.4b6. The scripts for the creation of the
> database schema are only for MySQL. I converted the script to PostgreSQL
> format, and modified ndo2db.c to enable PostgreSQL. But when I turn
> everything up, I see that there are also hardcoded queries with MySQL SQL
> format.
I thought most queries were in ANSI SQL. In what way are the queries
incompatible with PostgreSQL (or any other sql-engine, for that matter)?
> - is there a brach or something I'm missing, with a better grade of support
> for PostgreSQL?
Shouldn't think so. I haven't found one anyways.
> - is there somebody working in PostgreSQL support for NDOUtils (if yes,
> who)?
Not that I know of. Did google turn up blank?
OP5 AB www.op5.se
